Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74LVC02AQPWRG4Q1 — Даташит
СерияSN74LVC02A-Q1
МодельSN74LVC02AQPWRG4Q1
Каталог автомобилей Четырехканальный вентиль положительного ИЛИ-НЕ с 2 входами 14-TSSOP от -40 до 125
Quadruple 2-Input Positive-NOR Gate datasheet
PDF, 786 Кб, Версия: C, Файл опубликован: 9 апр 2008
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаLC02AQ
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bits4
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
RatingAutomotive
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)2 В
Voltage(Nom)2.7,3.3 В
tpd @ Nom Voltage(Max)6.5,5.5 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Gate > NOR Gate
На английском языке: Datasheet Texas Instruments SN74LVC02AQPWRG4Q1
Публикации по теме
