Datasheet Texas Instruments SN74HC163PWT — Даташит
Серия | SN74HC163 |
Модель | SN74HC163PWT |
4-битные синхронные двоичные счетчики 16-TSSOP от -40 до 85
SN54HC163, SN74HC163 datasheet
PDF, 957 Кб, Версия: D, Файл опубликован: 2 окт 2003
![]() 30 предложений от 17 поставщиков IC COUNTER 4BIT SYNC BIN 16TSSOP. Counter IC Binary Counter 1 Element 4 Bit Positive Edge 16-TSSOP. Logic - Counters, Dividers... | |||
SN74HC163PWT Texas Instruments | 87 ₽ | ||
SN74HC163PWT Texas Instruments | от 123 ₽ | ||
SN74HC163PWT Texas Instruments | по запросу |
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | HC163 |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 28 Mhz |
Function | Counter |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 5.2/-5.2 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rating | Catalog |
Technology Family | HC |
Тип | Binary |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Voltage(Nom) | 3.3,5 В |
tpd @ Nom Voltage(Max) | 46 нс |
- HCMOS Design Considerations (Rev. A)PDF, 207 Кб, Версия: A, Файл опубликован: 9 сен 2002
This document describes a potential problem designers may encounter when using high-speed CMOS (HC) logic devices. There also is a broad range of CMOS-system to non-CMOS-system interfaces that need to be considered. The design engineer inevitably encounters these interfaces. Key considerations for handling these interfaces are also discussed in this book.
Серия: SN74HC163 (11)
- Semiconductors > Logic > Specialty Logic > Counter/Arithmetic/Parity Function
