Datasheet Texas Instruments THS4503IDGNRG4 — Даташит
СерияTHS4503
МодельTHS4503IDGNRG4
Высокоскоростные полностью дифференциальные усилители 8-MSOP-PowerPAD от -40 до 85
Wideband, Low-Distortion Fully Differential Amplifiers. datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 7 окт 2011
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
2nd Harmonic(dBc)83
3rd Harmonic(dBc)97
@ MHz8
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)4.36 | 1ku
АрхитектураFully Differential
BW @ Acl(MHz)370
CMRR(Min)(dB)74
CMRR(Typ)(dB)80
GBW(Typ)(MHz)300
Input Bias Current(Max)(pA)4600000
Iq per channel(Max)(mA)28
Iq per channel(Typ)(mA)23
Number of Channels(#)1
Offset Drift(Typ)(uV/C)10
-40 to 85
Output Current(Typ)(mA)120
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L (PKG)See datasheet (SON)
Rail-to-RailNo
Slew Rate(Typ)(V/us)2800
Total Supply Voltage(Max)(+5V=5, +/-5V=10)15
Total Supply Voltage(Min)(+5V=5, +/-5V=10)4.5
Vn at Flatband(Typ)(nV/rtHz)6.8
Vos (Offset Voltage @ 25C)(Max)(mV)4
RoHSНе совместим
  • Evaluation Modules & Boards: THS4503EVM
    THS4503 Evaluation Module
  • Evaluation Modules & Boards: ADS5232EVM
    ADS5232 Evaluation Module
  • Evaluation Modules & Boards: ADS5231EVM
    ADS5231 Evaluation Module
  • Evaluation Modules & Boards: THS7530EVM
    THS7530 Evaluation Module
На английском языке: Datasheet Texas Instruments THS4503IDGNRG4
