Datasheet Texas Instruments TLV1549CP — Даташит
СерияTLV1549
МодельTLV1549CP
10-разрядный АЦП, 38 тыс.
10-Bit Analog-to-Digital Converters With Serial Control datasheet
PDF, 810 Кб, Версия: C, Файл опубликован: 1 мар 1995
импульсов в секунду, сер. Выход, встроенная функция S&H, совместимость с терминалами. С TLC1549, TLC1549x 8-PDIP
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаTLV1549CP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
# Input Channels1
Analog Voltage AVDD(Max)3.6 В
Analog Voltage AVDD(Min)3 В
АрхитектураSAR
Digital Supply(Max)3.6 В
Digital Supply(Min)3 В
INL(Max)1 +/-LSB
Input Range(Max)3.6 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSPI
Multi-Channel ConfigurationN/A
Package GroupPDIP
Power Consumption(Typ)1.32 mW
Reference ModeExt
Разрешение10 Bits
Sample Rate (max)38kSPS SPS
Sample Rate(Max)0.038 MSPS
  • Interfacing the TLV1549 10-Bit Serial-Out ADC to Popular 3.3-V Microcontrollers
    PDF, 90 Кб, Файл опубликован: 1 янв 1994
    The TLV1549, 10-bit serial-out A/ D converter operates with a 3.3-V (+/- 0.3 V) single supply. The device uses a switched-capacitor successive approximation method to perform the A/D conversion in a maximum of 21 ?s. This document describes interfacing the TLV1549 to three microcontrollors, 68HC05, TMS70C02, and 80C51-L, which operate from a single 3.3-V supply rail. Each interface requires no glu
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
На английском языке: Datasheet Texas Instruments TLV1549CP
