Datasheet Texas Instruments LM2596T-ADJ/LF02 — Даташит
СерияLM2596
МодельLM2596T-ADJ/LF02
SIMPLE SWITCHER® Понижающий стабилизатор с малым количеством компонентов, 4,5–40 В, 3 А, 5-220
LM2596 SIMPLE SWITCHERВ® Power Converter 150-kHz 3-A Step-Down Voltage Regulator datasheet
PDF, 5.1 Мб, Версия: D, Файл опубликован: 31 май 2016
36 предложений от 16 поставщиков
LM2596T-ADJ/LF02
253 ₽
LM2596T-ADJ/LF02
253 ₽
LM2596T-ADJ/LF02
от 604 ₽
727GS
LM2596T-ADJ/LF02
Pin55
Package TypeNEBNEB
Package QTY4545
CarrierTUBETUBE
МаркировкаLM2596T-ADJ P+
Control ModeVoltage Mode
Duty Cycle(Max)100 %
Iout(Max)3 A
Iq(Typ)5 мА
Package GroupTO-220
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)173 kHz
Switching Frequency(Min)110 kHz
ТипConverter
Vin(Max)40 В
Vin(Min)4.5 В
Vout(Max)37 В
Vout(Min)3.3 В
  • Evaluation Modules & Boards: LM2596S-ADJEVM
    LM2596 Step-Down Converter Evaluation Module
  • Buck Converters Provide a Battery Charger and System Power
    PDF, 61 Кб, Файл опубликован: 21 мар 2007
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Simple Techniques Minimize Cross-Coupling in Distributed Power Systems
    PDF, 335 Кб, Файл опубликован: 21 мар 2007
  • AN-1082 Adjust or Synchronize LM2586/88 Switching Frequency (Rev. B)
    PDF, 69 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Switching frequency is a very important parameter in switching power converters. As the switchingfrequency increases, the physical size of magnetic elements and other components in the circuit reducesignificantly. Switching frequency also plays a great role in control loop gain and compensation design.Switching frequency determines the maximum allowable bandwidth of the control loop. Switchi
  • AN-1081 Low-Cost Low-Parts-Count DC/DC Converter With Multiple Outputs (Rev. B)
    PDF, 124 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report describes a simple low cost, low parts-count multiple output DC/DC converterbased on the LM2596 five terminal step-down switching regulator. The circuit described provides multipleoutput voltages (positive and negative) with good regulation using a step-down converter circuit withflyback windings. It uses only one switching regulator IC.
LM2596TADJ/LF02, LM2596T ADJ/LF02
На английском языке: Datasheet Texas Instruments LM2596T-ADJ/LF02
