Datasheet Texas Instruments TPS544C25RVFR — Даташит
СерияTPS544C25
МодельTPS544C25RVFR
Понижающий преобразователь постоянного тока от 4,5 В до 18 В, 30 А PMBus™ SWIFT™ с FSYNC 40-LQFN-CLIP от -40 до 125
TPS544x25 4.5-V to 18-V, 20-A and 30-A SWIFT Synchronous Buck Converters with PMBus and Frequency Synchronization datasheet
PDF, 3.1 Мб, Файл опубликован: 15 май 2015
Pin40
Package TypeRVF
Industry STD TermLQFN-CLIP
JEDEC CodeR-PQFP-N
Package QTY2500
МаркировкаTPS544C25
Width (мм)5
Length (мм)7
Thickness (мм)1.46
Pitch (мм).5
Max Height (мм)1.52
Control ModeVoltage Mode
Duty Cycle(Max)80 %
Iout(Max)30 A
Iq(Typ)7.7 мА
Package GroupLQFN-CLIP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Dynamic Voltage Scaling,Enable,Frequency Synchronization,PMBus,Power Good,Pre-Bias Start-Up,Remote Sense,Synchronous Rectification,Tracking,UVLO Adjustable,Voltage Margining
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)18 В
Vin(Min)4.5 В
Vout(Max)5 В
Vout(Min)0.5 В
  • Evaluation Modules & Boards: TPS544C25EVM-681
    TPS544C25EVM-681 Evaluation Module
  • MOSFET power losses and how they affect power-supply efficiency
    PDF, 162 Кб, Файл опубликован: 26 янв 2016
  • Not All Jitter Is Created Equal (Rev. A)
    PDF, 555 Кб, Версия: A, Файл опубликован: 4 июл 2015
    This application report offers a tutorial discussion on jitter in switching DC-DC converters. Not all power supply designs are equally susceptible to jitter, nor are they equally affected by jitter. Modes of switching jitter are defined and explained for several popular control architectures, which are then analyzed for sources of jitter. An example contrasting the amount of jitter and effect on o
  • SMT Guidelines for Stacked Inductor (Inductor On Top) on Voltage Regulator IC
    PDF, 409 Кб, Файл опубликован: 22 фев 2016
Серия: TPS544C25 (2)
На английском языке: Datasheet Texas Instruments TPS544C25RVFR
