Datasheet Texas Instruments UA7805CKTER — Даташит
| Серия | UA7805 |
| Модель | UA7805CKTER |
Datasheet
Купить UA7805CKTER на РадиоЛоцман.Цены — от 63 до 660 ₽15 предложений от 13 поставщиков IC REG LINEAR 5V 1.5A 3POWERFLEX. Linear Voltage Regulator IC 1 Output 1.5A 3-PowerFLEXTM. PMIC - Voltage Regulators - Linear... | |||
| UA7805CKTER Texas Instruments | 63 ₽ | ||
| UA7805CKTER Texas Instruments | 141 ₽ | ||
| UA7805CKTER Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 3 |
| Package Type | KTE |
| Industry STD Term | PFM |
| JEDEC Code | R-PSFM-G |
| Маркировка | UA7805C |
| Width (мм) | 8 |
| Length (мм) | 9.4 |
| Thickness (мм) | 1.91 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 2.03 |
| Mechanical Data | Скачать |
| Accuracy(%) | 4 |
| Additional Features | Overcurrent Protection Thermal Shutdown |
| Approx. Price (US$) | 0.18 | 1ku |
| Fixed Output Options(V) | 5 |
| Iout(Max)(A) | 1.5 |
| Iq(Typ)(mA) | 4.3 |
| Noise(uVrms) | 40 |
| Operating Temperature Range(C) | 0 to 125 |
| Output Capacitor Type | Cap Free Non-Ceramic |
| Output Options | Fixed Output |
| Package Group | DDPAK/TO-263 TO-220 |
| Package Size: mm2:W x L (PKG) | See datasheet (TO-220) See datasheet (PFM) |
| Powered Load | FPGA Microcontroller Microprocessor |
| Rating | Catalog |
| Regulated Outputs(#) | 1 |
| Vdo(Typ)(mV) | 2000 |
| Vin(Max)(V) | 25 |
| Vin(Min)(V) | 7 |
| Vout(Max)(V) | 5 |
| Vout(Min)(V) | 5 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Evaluation Modules & Boards: LM317A-337N-EVM
3-Terminal Adjustable Regulators Evaluation Module
- How to pick a linear regulator for noise-sensitive applicationsPDF, 255 Кб, Файл опубликован: 22 янв 2013
- ANY-OUTв„ў LDO Controlled by I2Cв„ў IO Expander Device (Rev. A)PDF, 1.2 Мб, Версия: A, Файл опубликован: 20 сен 2012
TPS74201, TPS74301, TPS74401, TPS7A80xx, TPS7A8101 ANY-OUTв„ў LDO Controlled by I2Cв„ў IO Expander Device - Hybrid Battery Charger with Load Control for Telecom EquipmentsPDF, 391 Кб, Файл опубликован: 28 окт 2014
- A 3-A, 1.2-Vout linear regulator with 80% efficiency and Plost < 1WPDF, 158 Кб, Файл опубликован: 10 окт 2006
- A Topical Index of TI Supply Voltage Supervisor (SVS) Application NotesPDF, 56 Кб, Файл опубликован: 15 июн 2015
- Techniques for accurate PSRR measurementsPDF, 1.9 Мб, Файл опубликован: 28 окт 2013
- Selecting the correct IC for power-supply applicationsPDF, 184 Кб, Файл опубликован: 14 дек 2006
- Linear power for automated industrial systemsPDF, 1.8 Мб, Файл опубликован: 9 янв 2015
Designing a robust power management system for industrial automated equipment requires thorough understanding of the surroundings and conditions that affect the functionality. During the past few decades industrial and factory automation systems have become more robust intelligent and connected which has drastically increased the footprint for semiconductor components. This change has created a - Linear and Switching Voltage Regulator Fundamental Part 1PDF, 183 Кб, Файл опубликован: 21 мар 2007
- AN-1028 Maximum Power Enhancement Techniques for Power Packages (Rev. B)PDF, 684 Кб, Версия: B, Файл опубликован: 6 май 2013
The purpose of this application report is to aid the user in maximizing the power handling capability of Texas Instruments power packages by using the SOT-223 as an example.
Серия: UA7805 (5)
- UA7805CKC UA7805CKCE3 UA7805CKTER UA7805QKC UA7805QKTE
