Datasheet Texas Instruments DAC5675AHFG/EM — Даташит
СерияDAC5675A-SP
МодельDAC5675AHFG/EM
Цифро-аналоговый преобразователь класса V, 14 бит, 400 MSPS, только 52-CFP 25
DAC5675A-SP Radiation-Tolerant, 14-Bit, 400-MSPS Digital-to-Analog Converter datasheet
PDF, 818 Кб, Версия: H, Файл опубликован: 4 авг 2016
АЦП азиатских производителей
Pin5252
Package TypeHFGHFG
Industry STD TermCFPCFP
JEDEC CodeS-PQFP-FS-PQFP-F
Package QTY11
МаркировкаDAC5675AHFG/EMEVAL ONLY
Width (мм)13.9713.97
Length (мм)13.9713.97
Thickness (мм)3.423.42
Pitch (мм).64.64
Max Height (мм)3.423.42
АрхитектураCurrent Sink
DAC Channels1
DNL(Max)2 +/-LSB
Gain Error(Max)10 %FSR
INL(Max)4 +/-LSB
InterfaceParallel LVDS
Рабочий диапазон температурот -55 до 115,-55 до 125,25 Only C
Output Range Max.20 мА
Output Range Min.2 мА
Тип выходаCurrent
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
Power Consumption(Typ)660 mW
RatingSpace
Reference: TypeInt
Разрешение14 Bits
SFDR82 дБ
SNR67 дБ
Sample / Update Rate400 MSPS
Время установления0.012 µs
RoHSSee ti.com
  • Evaluation Modules & Boards: DAC5675AEVM
    DAC5675A 14-Bit, 400-MSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • High Speed Digital-to-Analog Converters Basics (Rev. A)
    PDF, 829 Кб, Версия: A, Файл опубликован: 23 окт 2012
Серия: DAC5675A-SP (3)
  • Semiconductors > Space & High Reliability > Data Converter > Digital to Analog Converters
На английском языке: Datasheet Texas Instruments DAC5675AHFG/EM
Публикации по теме
