Datasheet ТI UCC3888N — Даташит
СерияUCC3888
МодельUCC3888N
Datasheet Texas Instruments UCC3888N
Контроллер автономного источника питания 8-PDIP от 0 до 70
  • DN-59A UCC3889 Bias Supply Controller EVM Kit - Schematic
    PDF, 144 Кб, Файл опубликован: 5 сен 1999
    This design note presents a schematic and a photograph of the top-side layout for the UCC3889 Off-Line Bias Supply Controller IC Evaluation Kit. This board accepts both conventional "through-hole" or leaded components as well as their surface-mount counterparts. An additional prototyping area allows engineers to further customize these units to address their projects' specific needs. Component lis
  • U-149 Elegantly Simple Off-Line Bias Supply for Very Low Power Applications
    PDF, 328 Кб, Файл опубликован: 5 сен 1999
    The UCC3889 controller is an off-line, low-power, low-voltage, regulated-bias power supply. The unique circuit topology in this device can be visualized as two cascaded flyback converters, each operating in the discontinuous mode, and both driven from a single external power switch. The significant benefit of this approach is voltage conversion ratios of 400V to 12V, with no transformer and low in
Серия: UCC3888 (2)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC3888N
Политика конфиденциальности
