Datasheet Texas Instruments SN74LVC04ADBLE — Даташит
СерияSN74LVC04A
МодельSN74LVC04ADBLE
Шестигранный инвертор 14-SSOP от -40 до 125
SNx4LVC04A Hex Inverters datasheet
PDF, 1.4 Мб, Версия: T, Файл опубликован: 12 дек 2016
SN74LVC04ADBLE
SN74LVC04ADBLE
727GS
SN74LVC04ADBLE
Pin14
Package TypeDB
Industry STD TermSSOP
Width (мм)5.3
Length (мм)6.2
Thickness (мм)1.95
Max Height (мм)2
Approx. Price (US$)0.08 | 1ku
Bits(#)6
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.01
Тип входаCMOS
TTL
Operating Temperature Range(C)-40 to 125
Output Drive (IOL/IOH)(Max)(mA)-24/24
Тип выходаCMOS
Package GroupSSOP
Package Size: mm2:W x L (PKG)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
2.7
3.3
tpd @ Nom Voltage(Max)(ns)8
7.5
5.5
4.5
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LVC04ADBLE
