Линейка продуктов KEEN SIDE
Datasheet Texas Instruments DAC8541Y/2K — Даташит
СерияDAC8541
МодельDAC8541Y/2K
Маломощный 16-разрядный цифро-аналоговый преобразователь с поддержкой параллельной ПЧ 1,8 В, выходное напряжение Rail-to-Rail 32-TQFP от -40 до 85
16-Bit, Single Channel, Parallel Input Digital-to-Analog Converter with Rail-to- datasheet
PDF, 1.1 Мб, Файл опубликован: 5 дек 2001
Pin32
Package TypePBS
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY2000
Маркировка8541Y
Width (мм)5
Length (мм)5
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Code to Code Glitch(Typ)20 nV-sec
DAC ArchitectureString
DAC Channels1
Gain Error(Max)0.8 %FSR
INL(Max)65 +/-LSB
InterfaceParallel
Offset Error(Max)N/A %
Output Range Max.5.5 mA/V
Тип выходаBuffered Voltage
Package GroupTQFP
Package Size: mm2:W x L32TQFP: 49 mm2: 7 x 7(TQFP) PKG
Power Consumption(Typ)0.72 mW
Reference: TypeExt
Разрешение16 Bits
Sample / Update Rate0.1 MSPS
Время установления10 µs
Special FeaturesReset to Mid-Scale
Zero Code Error(Typ)0.8 мВ
  • Evaluation Modules & Boards: DAC8541EVM
    DAC8541 Evaluation Module
  • Interfacing with the DAC8541 Digital-to-Analog Converter
    PDF, 666 Кб, Файл опубликован: 13 июн 2002
    This application report shows how to interface and operate the DAC8541 with a commercially available microprocessor or Texas Instruments DSP. Although this report uses a DSP as an example for the host interface, the concept is generic in nature and therefore should fit any host processor selected to interface with this DAC. This report bridges the gap between digital signal system processing and a
  • Implementing a 4 mA to 20 mA Current Loop on TI DSPs
    PDF, 204 Кб, Файл опубликован: 5 янв 2004
    Use of 4-mA to 20-mA (4-20 mA) current loops has become the standard in the process-control industry due to their increased resistance to noise compared to voltage-modulated signals. TI digital signal processors (DSPs) increasingly are becoming the standard for microcontrollers in a control application. Therefore, an opportunity exists to connect the many sensors and electromechanical devices on t
Серия: DAC8541 (3)
На английском языке: Datasheet Texas Instruments DAC8541Y/2K
