Datasheet Texas Instruments SN74LVTH244AQDBREP — Даташит
СерияSN74LVTH244A-EP
МодельSN74LVTH244AQDBREP
Усовершенствованный продукт Восьмеричные буферы/драйверы с напряжением 3,3 В и выходами с 3 состояниями 20-SSOP от -40 до 125
SN74LVTH244A-EP datasheet
PDF, 436 Кб, Версия: C, Файл опубликован: 28 окт 2003
Pin20
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаLH244AEP
Width (мм)5.3
Length (мм)7.2
Thickness (мм)1.95
Max Height (мм)2
Bits8
Тип входаTTL
Тип выходаLVTTL
Package GroupSSOP
Package Size: mm2:W x L20SSOP: 56 mm2: 7.8 x 7.2(SSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
На английском языке: Datasheet Texas Instruments SN74LVTH244AQDBREP
Публикации по теме
