Datasheet Texas Instruments SN74LVC1G374YZPR — Даташит
| Серия | SN74LVC1G374 |
| Модель | SN74LVC1G374YZPR |
Один триггер типа D с выходом с 3 состояниями, 6-DSBGA от -40 до 85
SN74LVC1G374 datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 19 дек 2013
Купить SN74LVC1G374YZPR на РадиоЛоцман.Цены — от 9.54 до 50 ₽35 предложений от 16 поставщиков IC FF D-TYPE SNGL 1BIT 6DSBGA. Flip Flop 1 Element D-Type 1 Bit Positive Edge 6-XFBGA, DSBGA. Logic - Flip Flops... | |||
| SN74LVC1G374YZPR Texas Instruments | 13 ₽ | ||
| SN74LVC1G374YZPR Texas Instruments | 16 ₽ | ||
| SN74LVC1G374YZPR Texas Instruments | 43 ₽ | ||
| SN74LVC1G374YZPR Texas Instruments | 50 ₽ | ||
| Pin | 6 |
| Package Type | YZP |
| Industry STD Term | DSBGA |
| JEDEC Code | R-XBGA-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | D4N |
| Width (мм) | .9 |
| Length (мм) | 1.5 |
| Thickness (мм) | 2 |
| Pitch (мм) | .5 |
| Max Height (мм) | .5 |
| Mechanical Data | Скачать |
| 3-State Output | Yes |
| Bits | 1 |
| F @ Nom Voltage(Max) | 150 Mhz |
| Gate Type | FLIP-FLOP |
| ICC @ Nom Voltage(Max) | 0.01 мА |
| Logic | True |
| Рабочий диапазон температур | от -40 до 125,-40 до 85 C |
| Output Drive (IOL/IOH)(Max) | 32/-32 мА |
| Package Group | DSBGA |
| Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Special Features | Ioff,down translation to Vcc,low power |
| Sub-Family | D-Type Flip-Flop |
| Technology Family | LVC |
| VCC(Max) | 5.5 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,3.3,5 В |
| tpd @ Nom Voltage(Max) | 18.3,10.2,7,5 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G374 (4)
- 74LVC1G374DCKRG4 SN74LVC1G374DBVR SN74LVC1G374DCKR SN74LVC1G374YZPR
- Semiconductors > Logic > Little Logic
