Datasheet Texas Instruments TS3V340PW — Даташит
Серия | TS3V340 |
Модель | TS3V340PW |
Четырехполюсный видеопереключатель с высокой пропускной способностью и низким сопротивлением в открытом состоянии 16-TSSOP от -40 до 85
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 90 |
Carrier | TUBE |
Маркировка | TF340 |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Additional Features | Powered off protection |
Полоса частот | 500 МГц |
Bandwidth(Max) | 500 МГц |
Configuration | 2:1 SPDT |
Crosstalk | -80 дБ |
ESD Charged Device Model | 1 kV |
ESD HBM(Typ) | 2 kV |
ICC(Max) | 1500 uA |
ICC(Typ) | 700 uA |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 3.5 пФ |
Input/Output ON-state Capacitance(Typ) | 10.5 пФ |
Количество каналов | 4 |
OFF-state leakage current(Max) | 1 мкА |
Off Isolation(Typ) | -60 дБ |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Время задержки распространения | 2 нс |
Protocols | RGB,Composite |
RON Flatness(Typ) | 1 Ohms |
Ron(Max) | 6 Ohms |
Ron(Typ) | 3 Ohms |
Turn off Time (Disable)(Max) | 7 нс |
Turn on Time (Enable)(Max) | 7 нс |
VCC(Max) | 3.6 В |
VCC(Min) | 3 В |
VIH(Min) | 2 В |
VIL(Max) | 0.8 В |
- Preventing Excess Power Consumption on Analog SwitchesPDF, 238 Кб, Файл опубликован: 3 июл 2008
Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3V340 (10)
- Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
