Datasheet Texas Instruments SN74CBT3244DBLE — Даташит
Серия | SN74CBT3244 |
Модель | SN74CBT3244DBLE |
Восьмеричный переключатель шины на полевых транзисторах 20-SSOP от -40 до 85
SN74CBT3244 Octal FET Bus Switch datasheet
PDF, 1.4 Мб, Версия: O, Файл опубликован: 29 сен 2015
Pin | 20 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 5.3 |
Length (мм) | 7.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Additional Features | Low Power |
Approx. Price (US$) | 0.24 | 1ku |
Bandwidth(MHz) | 200 |
Configuration | SPST |
ESD Charged Device Model(kV) | 0.5 |
ESD HBM(kV) | 1.5 |
ICC(Max)(uA) | 50 |
Input/Ouput Voltage(Max)(V) | 5.5 |
Input/Output Continuous Current(Max)(mA) | 128 |
Number of Channels(#) | 8 |
Operating Temperature Range(C) | -40 to 85 |
Package Group | SSOP |
Package Size: mm2:W x L (PKG) | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) |
Rating | Catalog |
Ron(Max)(Ohms) | 7 |
Ron(Typ)(Ohms) | 5 |
VCC(Max)(V) | 5.5 |
VCC(Min)(V) | 4.5 |
RoHS | Не совместим |
- Evaluation Modules & Boards: ADS127L01EVM
ADS127L01 Evaluation Module
- Flexible Voltage-Level Translation With CBT Family DevicesPDF, 40 Кб, Файл опубликован: 20 июл 1999
Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency. - 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not - 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
- VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CBT3244 (14)
- Semiconductors > Switches and Multiplexers > Signal Switches > Digital Switch
