Datasheet Texas Instruments THS5641IPWR — Даташит
Серия | THS5641 |
Модель | THS5641IPWR |
8-битный, 100 MSPS, CommsDAC, диф. Масштабируемые токовые выходы от 2 мА до 20 мА 28-TSSOP от -40 до 85
Datasheet
Pin | 28 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Wideband Complementary Current Output DAC Single-Ended InterfacePDF, 597 Кб, Файл опубликован: 21 июн 2005
High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS5641 (4)
- THS5641IDW THS5641IDWR THS5641IPW THS5641IPWR
- Semiconductors > Data Converters > Digital to Analog Converter > Precision DAC (=<10MSPS)
