Datasheet Texas Instruments SN74AHCT240PWG4 — Даташит
СерияSN74AHCT240
МодельSN74AHCT240PWG4
Восьмеричные буферы/драйверы с выходами с 3 состояниями 20-TSSOP от -40 до 125
SNx4AHCT240 Octal Buffers/Drivers With 3-State Outputs datasheet
PDF, 1.5 Мб, Версия: M, Файл опубликован: 13 апр 2016
IC BUFFER INVERT 5.5V 20TSSOP. Buffer, Inverting 2 Element 4 Bit per Element 3-State Output 20-TSSOP. Logic - Buffers, Drivers, Receivers,...
SN74AHCT240PWG4
13 ₽
SN74AHCT240PWG4
19 ₽
Hi-Tech Circuit Group
SN74AHCT240PWG4
SN74AHCT240PWG4
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY70
МаркировкаHB240
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Bits8
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-8/8 мА
Package GroupTSSOP
Schmitt TriggerNo
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)10 нс
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AHCT240PWG4
