Datasheet Texas Instruments TS5A1066DCKR — Даташит
СерияTS5A1066
МодельTS5A1066DCKR
Аналоговый переключатель SPST 10 Ом 5-SC70 от -40 до 85
TS5A1066 datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 8 окт 2012
АЦП азиатских производителей
Pin555
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаJDRJD5JDF
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
Полоса частот400 МГц
Bandwidth(Max)400 МГц
Configuration1:1 SPST
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)50 мА
Input/Output OFF-state Capacitance(Typ)6.8 пФ
Input/Output ON-state Capacitance(Typ)14 пФ
Количество каналов1
OFF-state leakage current(Max)2 мкА
ON-state leakage current(Max)2 мкА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Ron(Max)100 Ohms
Ron(Typ)7.5 Ohms
Supply Current(Max)10 uA
Supply Range5.5 Max
VIH(Min)vcc*.7 В
VIL(Max)vcc*.3 В
Vdd(Max)5.5 В
Vdd(Min)1.65 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Thermal Printer Reference Design Using TM4C1233H6PM
    PDF, 480 Кб, Файл опубликован: 27 мар 2014
    This application report discusses the complete hardware and software required for a thermal printer solution based on Texas Instruments Tivaв„ў controllers. Tiva controllers are 32-bit ARMВ® CortexВ®-M4 80-MHz processor core with IEEE754-compliant single-precision Floating-Point Unit (FPU), on-chip memory, featuring 256 KB single-cycle Flash, 32 KB single-cycle SRAM; internal ROM loaded
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A1066 (5)
На английском языке: Datasheet Texas Instruments TS5A1066DCKR
