Datasheet Texas Instruments AM26LV32CNSLE — Даташит
| Серия | AM26LV32 |
| Модель | AM26LV32CNSLE |
Низковольтный высокоскоростной четырехкратный дифференциальный линейный приемник 16-SO от 0 до 70
AM26LV32 Low-Voltage, High-Speed Quadruple   Differential Line Receiver datasheet
PDF, 1.0 Мб, Версия: F, Файл опубликован: 18 ноя 2016
LOW-VOLTAGE HIGH-SPEED QUADRUPLE DIFFERENTIAL LINE RECEIVER  | |||
| AM26LV32CNSLE Texas Instruments  | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 16 |
| Package Type | NS |
| Industry STD Term | SOP |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 5.3 |
| Length (мм) | 10.3 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
Рекомендуемая замена
| Replacement | AM26LV32CNSR |
| Replacement Code | S |
| # of TX/RX | 0 TX / 4 RX |
| Approx. Price (US$) | 0.47 | 1ku |
| ESD(kV) | 2 |
| Footprint | AM26LS32 |
| ICC(Max)(mA) | 17 |
| Operating Temperature Range(C) | -40 to 85 0 to 70  |
| Package Group | SO |
| Package Size: mm2:W x L (PKG) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) |
| Rating | Catalog |
| Receiver tpd(ns) | 16 |
| Receivers Per Package | 4 |
| Signaling Rate(Mbps) | 32 |
| Supply Voltage(s)(V) | 3.3 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Wave Solder Exposure of SMT PackagesPDF, 206 Кб, Файл опубликован: 9 сен 2008
It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
Серия: AM26LV32 (17)
- Semiconductors > Interface > RS-422 Transceivers
