Datasheet Texas Instruments LMP7721MAX/NOPB — Даташит
СерияLMP7721
МодельLMP7721MAX/NOPB
Прецизионный усилитель входного тока смещения с 3 фемтоамперами 8-SOIC от -40 до 125
LMP7721 3-Femtoampere Input Bias Current Precision Amplifier datasheet
PDF, 1.0 Мб, Версия: E, Файл опубликован: 15 дек 2014
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка21MALMP77
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesN/A
АрхитектураCMOS
CMRR(Min)84 дБ
CMRR(Typ)100 дБ
GBW(Typ)17 МГц
Input Bias Current(Max)0.02 pA
Iq per channel(Max)1.7 мА
Iq per channel(Typ)1.3 мА
Количество каналов1
Offset Drift(Typ)1.5 uV/C
Output Current(Typ)22 мА
Rail-to-RailIn to V-,Out
Slew Rate(Typ)10.5 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)6.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.15 мВ
  • Evaluation Modules & Boards: LMP7721MAEVALMF/NOPB
    LMP7721 Multi-Function Evaluation Board
  • AN-1798 Designing with Electro-Chemical Sensors (Rev. C)
    PDF, 62 Кб, Версия: C, Файл опубликован: 1 май 2013
    As early as 1950, electro-chemical sensors were used for oxygen (gas) monitoring; however, with increasing concerns about personal safety, the demand for portable electro-chemical sensors has dramatically increased. Today, electro-chemical sensors are commonly used in portable equipment todetect different toxic gases.
  • AN-1852 Designing With pH Electrodes (Rev. A)
    PDF, 115 Кб, Версия: A, Файл опубликован: 1 май 2013
    A pH electrode measures hydrogen ion (H+) activity and produces an electrical potential or voltage. Theoperation of the pH electrode is based on the principle that an electric potential develops when two liquidsof different pH come into contact at opposite sides of a thin glass membrane. This was originallydiscovered in 1906 by Max Cremer [1]. His discovery laid the foundation for Fritz Habe
Серия: LMP7721 (2)
На английском языке: Datasheet Texas Instruments LMP7721MAX/NOPB
