Datasheet Texas Instruments TPS62082DSGT — Даташит
СерияTPS62082
МодельTPS62082DSGT
Высокоэффективный понижающий преобразователь 1,2 А в корпусе SON 2x2 мм. 3,3 Vвых (мин) 8-WSON от -40 до 125
TPS6208x 1.2-A High-Efficiency, Step-Down Converter With DCS-Control and Snooze Mode datasheet
PDF, 2.0 Мб, Версия: F, Файл опубликован: 16 ноя 2016
Package TypeDSG
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаQVT
Width (мм)2
Length (мм)2
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Control ModeConstant on-time (COT)
Duty Cycle(Max)100 %
Iout(Max)1.2 A
Iq(Typ)0.006 мА
Package GroupWSON
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Output Discharge,Power Good,Synchronous Rectification
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)2000 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)2.3 В
Vout(Max)3.3 В
Vout(Min)3.3 В
  • Evaluation Modules & Boards: TUSB320EVM
    TUSB320 Evaluation Module (EVM)
  • Evaluation Modules & Boards: DP141RLJEVM
    DP141 DisplayPort Linear Redriver Supporting RBR, HBR, HBR2 and HBR3 (12Gbps) Evaluation Module
  • Evaluation Modules & Boards: TUSB1042EVM
    TUSB1042 10Gbps USB3.1G2 2:1 Linear Redriver Switch Evaluation Module
  • Evaluation Modules & Boards: TUSB544RNQEVM
    TUSB544 USB Type-C TM 8.1 Gbps Multi-Protocol Linear Redriver Evaluation Module
  • Evaluation Modules & Boards: TPS62080EVM-641
    1.2-A, High-Efficiency, Step-Down Converter Evaluation Module
  • Evaluation Modules & Boards: TUSB322EVM
    TUSB322 USB Type-C Configuration Channel Logic and Port Control With VCONN Evaluation Module
  • Evaluation Modules & Boards: TUSB320-LA-EVM
    TUSB320LAI USB Type-C Configuration Channel Logic and Port Control Evaluation Module
  • Evaluation Modules & Boards: TUSB320-HA-EVM
    TUSB320HAI USB Type-C Configuration Channel Logic and Port Control Evaluation Module
  • Evaluation Modules & Boards: 3220UFP-DGLEVM
    HD3SS3220 Type-C Up Facing Port Controller With SuperSpeed 2:1 MUX Evaluation Module
  • Evaluation Modules & Boards: 3220DFP-DGLEVM
    HD3SS3220 Type-C Down Facing Port Controller With SuperSpeed 2:1 MUX Evaluation Module
  • Evaluation Modules & Boards: TUSB546EVM
    TUSB546 USB Type-CВ™ Alternate Mode Redriver Switch EVM
  • Evaluation Modules & Boards: TUSB1046EVM
    TUSB1046 USB Type-CВ™ Alternate Mode Redriver Switch EVM
  • TPS6208x and TLV6208x Device Comparison
    PDF, 386 Кб, Файл опубликован: 4 окт 2016
  • How to Measure the Control Loop of DCS-Control Devices (Rev. A)
    PDF, 259 Кб, Версия: A, Файл опубликован: 9 авг 2012
  • High-efficiency low-ripple DCS-Control offers seamless PWM/pwr-save transitions
    PDF, 605 Кб, Файл опубликован: 25 июл 2013
  • Understanding frequency variation in the DCS-Control(TM) topology
    PDF, 224 Кб, Файл опубликован: 30 окт 2015
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS62082 (2)
На английском языке: Datasheet Texas Instruments TPS62082DSGT
