Datasheet Texas Instruments LMT87DCKT — Даташит
СерияLMT87
МодельLMT87DCKT
Датчик температуры с аналоговым выходом 2,7 В, 10 мкА в SC70 и TO-92 5-SC70 от -50 до 150
LMT87/LMT87-Q1 2.7-V, SC70/TO-92/TO-92S, Analog Temperature Sensors With Class-AB Output datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 23 июн 2017
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY250
CarrierSMALL T&R
МаркировкаBUA
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
InterfaceAnalog Output
Local Sensor Accuracy(Max)2.7 +/- C
Рабочий диапазон температурот -50 до 150 C
Package GroupTO-92
Package Size: mm2:W x L3TO-92: 13 mm2: 3.15 x 4(TO-92) PKG
Sensor Gain-13.6 mV/Deg C
Special FeaturesIndustry standard pinout
Supply Current(Max)8.1 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)2.7 В
  • Evaluation Modules & Boards: LMT84-7EVM
    EVM for LMT84, LMT85, LMT86 and LMT87 Temperature Sensor
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
  • Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT87DCKT
