Datasheet Texas Instruments 74CBTLV3245ADWRG4 — Даташит
СерияSN74CBTLV3245A
Модель74CBTLV3245ADWRG4
Низковольтный коммутатор шины Octal FET 20-SOIC от -40 до 85
SN74CBTLV3245A datasheet
PDF, 1.4 Мб, Версия: M, Файл опубликован: 23 май 2005
АЦП азиатских производителей
Pin20
Package TypeDW
Package QTY2000
МаркировкаCBTLV3245A
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Additional FeaturesPowered off protection
Полоса частот200 МГц
Configuration1:1 SPST
ESD HBM2 kV
Input/Ouput Voltage(Max)3.6 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)9 пФ
Количество каналов8
OFF-state leakage current(Max)60 мкА
ON-state leakage current(Max)60 мкА
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Ron(Max)40 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)10 uA
Supply Range3.6 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)3.6 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Evaluation Modules & Boards: EVMX777G-01-20-00
    J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
  • Evaluation Modules & Boards: TMDXEVM388
    DM388 DaVinci Digital Media Processor Evaluation Module
  • Evaluation Modules & Boards: EVMX777BG-01-00-00
    J6Entry, RSP and TDA2E-17 CPU Board Evaluation Module
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
На английском языке: Datasheet Texas Instruments 74CBTLV3245ADWRG4
