Datasheet Texas Instruments TPS54060QDGQRQ1 — Даташит
СерияTPS54060-Q1
МодельTPS54060QDGQRQ1
Automotive Catalog 3.5V to 60V Input, 0.5A, 2.5MHz Step Down SWIFTв„ў Converter with Eco-Mode 10-MSOP-PowerPAD -40 to 125
Datasheet
TSP
Pin10
Package TypeDGQ
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Маркировка5406Q
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.1
Рекомендуемая замена
ReplacementTPS57060QDGQRQ1
Replacement CodeS
  • TPS54xx0-Q1 and TPS57xx0-Q1 Pin Open and Short Test Results (Rev. B)
    PDF, 39 Кб, Версия: B, Файл опубликован: 3 ноя 2015
    This application note provides Pin Open and Short Test Results for the device pins of the TPS54xx0-Q1and TPS57xx0-Q1 family of step-down SWIFTв„ў DC-DC converters. The TPS54xx0-Q1 and TPS57xx0-Q1 family of power devices consists of high-input-voltage step-down regulators that provide a variety ofcurrent options.
  • Design Considerations for DC-DC Converters in Fast-Input Slew Rate Applications
    PDF, 191 Кб, Файл опубликован: 5 мар 2015
    This application report describes the ways to optimize the design of DC-DC converters (TPS54040-Q1, TPS54060-Q1, TPS54140-Q1, TPS54160-Q1, TPS54240-Q1, TPS54260-Q1, TPS57040-Q1, TPS57060-Q1, TPS57140-Q1, and TPS57160-Q1) in applications with fast transition at the input voltage on the rising and falling edges. First, the issues faced under such a scenario are analyzed. Then, design considerations
Серия: TPS54060-Q1 (1)
  • TPS54060QDGQRQ1
На английском языке: Datasheet Texas Instruments TPS54060QDGQRQ1
