Datasheet Texas Instruments TLC5940PWP — Даташит
СерияTLC5940
МодельTLC5940PWP
16-канальный светодиодный драйвер с коррекцией точек EEprom и ШИМ-управлением оттенков серого 28-HTSSOP от -40 до 85
TLC5940 16-Channel LED Driver With DOT Correction and Grayscale PWM Control datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 3 дек 2015
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY50
МаркировкаTLC5940
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Analog Dimming Steps64
Ch to Ch Accuracy(Typ)1 +/- %
Data Transfer Rate(Typ)30 МГц
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
Special FeaturesError Flag,Fault Detection,LED Open Detection,Power Good
  • TLC5940 One Wire Control--Eliminating Microprocessor Control for Integr LED Driv
    PDF, 410 Кб, Файл опубликован: 25 сен 2006
    LED drivers such as the TLC5940 provide many integrated features that require a microprocessor interface to use. When these features are not needed, the TLC5940 can be configured with a single-wire interface for simple on/off control. This provides a low-cost solution to drive multiple LEDs with tight current matching while still allowing for PWM dimming in applications such as backlighting or gen
  • TLC5940 PWM dimming provides superior color quality in LED video displays
    PDF, 215 Кб, Файл опубликован: 18 апр 2006
  • TLC5940 dot correction compensates for variations in LED brightness
    PDF, 175 Кб, Файл опубликован: 10 окт 2005
  • LED Display System Module Using Cascading TLC5940 Devices
    PDF, 496 Кб, Файл опубликован: 6 июл 2006
    Described in this document are application ideas and reference designs for the TLC5940 LED driver. The following application example shows the building of a basic module of an LED display system using a cascading connection on n TLC5940 devices connected to a controller. The reference design implements three TLC5940 devices to drive 16 LEDs.
  • Using the TLC5940 with Higher LED Supply Voltages and Series LEDs
    PDF, 353 Кб, Файл опубликован: 20 авг 2007
    This application report describes how to accommodate higher LED supply voltages and increase the number of series LEDs that the TLC5940 can drive.
  • Grayscale and Dot-Corrected LED Display Using TLC5941 (Rev. A)
    PDF, 198 Кб, Версия: A, Файл опубликован: 5 мар 2008
    The TLC5941 LED driver uses a serial data interface to receive grayscale and dot correction data. This application report discusses the hardware and firmware to drive the TLC5941 with a MSP430F427 microcontroller.
  • LED Driver--Paralleled Outputs Provide High Current Outputs
    PDF, 957 Кб, Файл опубликован: 25 сен 2006
    This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
На английском языке: Datasheet Texas Instruments TLC5940PWP
