Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74LVC1T45DBVT — Даташит
СерияSN74LVC1T45
МодельSN74LVC1T45DBVT
Однобитный приемопередатчик с двойной шиной питания, настраиваемым сдвигом уровня напряжения и выходами с 3 состояниями 6-SOT-23 от -40 до 85
SN74LVC1T45 Single-Bit Dual-Supply Bus Transceiver With Configurable Voltage Translation and 3-State Outputs datasheet
PDF, 1.4 Мб, Версия: L, Файл опубликован: 21 фев 2017
Pin666
Package TypeDBVDBVDBV
Industry STD TermSOT-23SOT-23SOT-23
Package QTY250250250
CarrierSMALL T&RSMALL T&RSMALL T&R
МаркировкаCT1FCT15CT1R
Width (мм)1.61.61.6
Length (мм)2.92.92.9
Thickness (мм)1.21.21.2
Pitch (мм).95.95.95
Max Height (мм)1.451.451.45
3-State OutputYes
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeTRANSCEIVER
ICC @ Nom Voltage(Max)0.004 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerNo
Special FeaturesIoff,Dual Supply,Translation
Sub-FamilyDual Supply Translator
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)15.5,8,5.8,4.4 нс
  • Evaluation Modules & Boards: AVCLVCDIRCNTRL-EVM
    Generic EVM for Direction-Controlled Bidirectional Translation Device Supporting AVC and LVC
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1T45DBVT
