Datasheet Texas Instruments UC3707J — Даташит
СерияUC3707M
МодельUC3707J
Дополнительные высокоскоростные драйверы питания 16-CDIP от 0 до 70
Dual Channel Power Driver datasheet
PDF, 973 Кб, Версия: B, Файл опубликован: 16 сен 2008
Драйвер FET, MOSFET DRVR 1.5A 2Out High Speed Inv/Non-Inv 16Pin CDIP
UC3707J
1 514 ₽
UC3707J
1 514 ₽
UC3707J
UC3707J
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаUC3707J
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Channel Input LogicN/A
Fall Time40 нс
Input ThresholdTTL
Input VCC(Max)40 В
Input VCC(Min)5 В
Количество каналов2
Package GroupCDIP
Peak Output Current3.5 A
Power SwitchMOSFET,IGBT
Prop Delay100 нс
RatingMilitary
Rise Time40 нс
Special FeaturesAnalog Shutdown with Optional Latch,Thermal Shutdown
RoHSSee ti.com
  • U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching Characteristics
    PDF, 573 Кб, Файл опубликован: 5 сен 1999
    The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola
  • U-137 Practical Considerations in High Performance MOSFET IGBT and MCT Gate
    PDF, 244 Кб, Файл опубликован: 5 сен 1999
    The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad
Серия: UC3707M (1)
  • UC3707J
  • Semiconductors > Power Management > MOSFET and IGBT Gate Drivers > Low-side Driver
На английском языке: Datasheet Texas Instruments UC3707J
