Datasheet Texas Instruments TMS320C6742BZWTA2 — Даташит
СерияTMS320C6742
МодельTMS320C6742BZWTA2
Процессор цифровых сигналов с фиксированной/плавающей запятой 361-NFBGA от -40 до 105
TMS320C6742 Fixed- and Floating-Point DSP datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 31 янв 2017
Цифровой сигнальный процессор DSP, DSP Fixed-Point/Floating-Point 16Bit 200MHz 1600MIPS 361Pin NFBGA
TMS320C6742BZWTA2
1 188 ₽
TMS320C6742BZWTA2
1 394 ₽
LifeElectronics
TMS320C6742BZWTA2
Hi-Tech Circuit Group
TMS320C6742BZWTA2
Pin361361361
Package TypeZWTZWTZWT
Industry STD TermNFBGANFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
МаркировкаC6742BZWTTMS320A200
Width (мм)161616
Length (мм)161616
Thickness (мм).9.9.9
Pitch (мм).8.8.8
Max Height (мм)1.41.41.4
ApplicationsCommunications and Telecom
Approx. Price (US$)6.30 | 1ku
DRAMLPDDR
DDR2
DSP1 C674x
DSP MHz (Max.)200
I2C1
On-Chip L2 Cache64 KB
Operating SystemsSYS/BIOS
Operating Temperature Range(C)-40 to 105
0 to 90
SATA1
SPI1
UART(SCI)1
RoHSНе совместим
  • Development Kits: TMDXLCDK138
    OMAP-L138 Development Kit (LCDK)
  • Development Kits: TMDXLCDK6748
    TMS320C6748 DSP Development Kit (LCDK)
  • Development Kits: TMDSLCDK6748
  • Development Kits: TMDSLCDK138
    XDS200 USB Debug Probe
  • TMS320C6748/46/42 Complementary Products
    PDF, 26 Кб, Файл опубликован: 20 июл 2009
    This article has been contributed to the TI DaVinciв„ў and OMAPв„ў Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://tiexpressdsp.com/index.php/C6748/46/42_Complementary_Products .This Wiki article serves as a repository of complimentary devices tha
  • Using the TMS320C6748/C6746/C6742 Bootloader (Rev. F)
    PDF, 1.6 Мб, Версия: F, Файл опубликован: 23 янв 2014
    This application report describes various boot mechanisms supported by the C6748/C6746/C6742 bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, def
  • TMS320C6748/46/42 Power Consumption Summary
    PDF, 19 Кб, Файл опубликован: 30 авг 2010
    This article discusses the power consumption of the Texas Instruments C6748/46/42. Power consumption on the C6748/46/42 devices are highly application-dependent. The low-core voltage and other power design optimizations allow these devices to operate with industry-leading performance, while maintaining a low power-to-performance ratio.The power data presented in this document are based on mea
  • Powering the TMS320C6742, TMS320C6746, and TMS320C6748 With the TPS650061
    PDF, 312 Кб, Файл опубликован: 19 дек 2011
    This document details the design considerations of a power solution for the TMS320C742,TMS320C6746, and TMS320C6748 (TMS320C6742/C6746/C6748) low-power application processor witha TPS650061, three-rail power management unit (PMU) or power management integrated circuit (PMIC).Portable application solution size demands a high level of integration and the TMS320C6742/C6746/C6748 requires at l
  • OMAP-L132/L138, TMS320C6742/6/8 Pin Multiplexing Utility (Rev. B)
    PDF, 37 Кб, Версия: B, Файл опубликован: 27 сен 2013
    The OMAP-L1x8 and C6742/6/8 devices use a great deal of internal pin multiplexing to allow the most functionality in the smallest and lowest cost package. This software allows the pin multiplexing registers of the device to be calculated with ease, as well as showing what peripherals can be used together and what devices support the peripherals that are selected. This software is useful to anyone
  • Medium Integrated Power Solution Using a Dual DC/DC Converter and an LDO (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, or OMAP-L132/L138 processor. Using sequenced power supplies, this reference design describes a system having a 3.3-V input voltage and a high-efficiency dc/dc converter with integrated FETs for a small, simple design.Sequenced power supply architectures are becoming commonplace in high-performan
  • Simple Power Solution Using LDOs (Rev. B)
    PDF, 150 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This reference design helps those desiring to design-in the TMS320C6742, TMS320C6746, TMS320C6748, and OMAP-L132/L138. This design, employing sequenced power supplies, describes asystem with an input voltage of 3.3 V, and uses LDOs for a small, simple system.Sequenced power supply architectures are becoming commonplace in high-performance microprocessor and digital signal processor (DSP) syste
  • High-Vin, High-Efficiency Power Solution Using DC/DC Converter With DVFS (Rev. C)
    PDF, 266 Кб, Версия: C, Файл опубликован: 29 авг 2011
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, or OMAP-L132/L138 processor. Using sequenced power supplies, this reference design describes a system having a 12-V input voltage and a high-efficiency dc/dc converter with integrated FETs and dynamic voltage and frequency scaling (DVFS) for a small, simple design.Sequenced power supply architec
  • High-Integration, High-Efficiency Power Solution Using DC/DC Converters w/DVFS (Rev. A)
    PDF, 208 Кб, Версия: A, Файл опубликован: 5 май 2010
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, OMAP-L138 or AM18x processor. Using sequenced power supplies, this reference design describes a system having a 12-V input voltage and a high-efficiency dc/dc converter with ntegrated FETs and dynamic voltage and frequency scaling (DVFS) for a small, simple design.Sequenced power supply archit
  • TMS320C6748/46/42 & OMAP-L132/L138 USB Downstream Host Compliance Testing
    PDF, 3.6 Мб, Файл опубликован: 17 авг 2009
    This application report describes the TMS320C6748/46/42 and OMAP-L1x8 embedded Host electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The OTG controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS) and low-speed (LS).
  • TMS320C6748/46/42 & OMAP-L1x8 USB Upstream Device Compliance Testing
    PDF, 1.1 Мб, Файл опубликован: 17 авг 2009
    This application report describes the TMS320C6748/46/42 and OMAP-L1x8 electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The on-the-go (OTG) controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS) and low-speed (LS).
  • High-Efficiency Power Solution Using DC/DC Converters With DVFS (Rev. A)
    PDF, 161 Кб, Версия: A, Файл опубликован: 5 май 2010
  • TI DSP Benchmarking
    PDF, 62 Кб, Файл опубликован: 13 янв 2016
    This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms.
  • TMS320C674x/OMAP-L1x USB Compliance Checklist
    PDF, 89 Кб, Файл опубликован: 12 мар 2009
    This application report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • OMAP-L1x/C674x/AM1x SOC Architecture and Throughput Overview
    PDF, 19 Кб, Файл опубликован: 12 фев 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/OMAP-L1x/C674x/AM1x_SOC_Architecture_and_Throughput_Overview. This collection of Wiki articles provide i
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > C674x DSP
На английском языке: Datasheet Texas Instruments TMS320C6742BZWTA2
