Datasheet Texas Instruments THS4021CDGN — Даташит
СерияTHS4021
МодельTHS4021CDGN
Сверхмалошумящий усилитель с обратной связью по напряжению, 350 МГц 8-MSOP-PowerPAD 0–70
350-MHz Low-Noise High-Speed Amplifiers datasheet
PDF, 1.2 Мб, Версия: C, Файл опубликован: 19 июл 2007
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY80
МаркировкаACK
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
2nd Harmonic68 dBc
3rd Harmonic69 dBc
@ MHz1
Acl, min spec gain10 V/V
Additional FeaturesDecompensated
АрхитектураBipolar,Voltage FB
BW @ Acl350 МГц
CMRR(Min)74 дБ
CMRR(Typ)95 дБ
GBW(Typ)3500 МГц
Input Bias Current(Max)6000000 pA
Iq per channel(Max)10 мА
Iq per channel(Typ)7.8 мА
Количество каналов1
Offset Drift(Typ)15 uV/C
Output Current(Typ)100 мА
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)470 V/us
Total Supply Voltage(Max)32 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.5 нВ/rtГц
Vn at Flatband(Typ)1.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Evaluation Modules & Boards: THS4021EVM
    THS4021 High Speed Amplifier Evaluation Module
  • Using a Decompensated Operational Amplifier for Improved Performance
    PDF, 161 Кб, Файл опубликован: 30 мар 2001
    Decompensated operational amplifiers have improved noise, slew rate, harmonic distortion, etc., but required external compensation for stable operation. This report shows how to compensate such an amplifier and achieve the performance enchancement it provides in a unity-gain configuration.The THS4011 and THS4021 operational amplifiers are used to illustrate the superior performance mentioned a
  • Using a decompensated op amp for improved performance
    PDF, 352 Кб, Файл опубликован: 11 мар 2005
На английском языке: Datasheet Texas Instruments THS4021CDGN
