Datasheet Texas Instruments OPA569AIDWPRG4 — Даташит
СерияOPA569
МодельOPA569AIDWPRG4
Операционный усилитель мощности, колебания выходного сигнала в пределах 200 мВ от шины при выходном токе 2 А 20-SO PowerPAD от -55 до 125
OPA569: Rail-To-Rail I/O, 2A Power Amplifier datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 22 окт 2003
Pin20
Package TypeDWP
Industry STD TermHSOIC
Width (мм)7.52
Length (мм)12.82
Thickness (мм)2.55
Max Height (мм)2.65
Additional FeaturesAdj Current Limit
Shutdown
Approx. Price (US$)3.90 | 1ku
АрхитектураFET
CMRR(Min)(dB)70
CMRR(Typ)(dB)90
GBW(Typ)(MHz)1.2
Input Bias Current(Max)(pA)10
Iq per channel(Max)(mA)11
Iq per channel(Typ)(mA)9
Number of Channels(#)1
Offset Drift(Typ)(uV/C)1.3
Operating Temperature Range(C)-55 to 125
Output Current(Typ)(mA)2400
Package GroupSO PowerPAD
Package Size: mm2:W x L (PKG)20SO PowerPAD: 133 mm2: 10.405 x 12.825(SO PowerPAD)
Rail-to-RailIn to V-
Out
Slew Rate(Typ)(V/us)1.2
Total Supply Voltage(Max)(+5V=5, +/-5V=10)5.5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.7
Vos (Offset Voltage @ 25C)(Max)(mV)2
RoHSНе совместим
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
Серия: OPA569 (4)
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA569AIDWPRG4
