Линейка продуктов KEEN SIDE
Datasheet Texas Instruments LM2575HVN-ADJ/NOPB — Даташит
СерияLM2575HV
МодельLM2575HVN-ADJ/NOPB
ПРОСТОЙ ПЕРЕКЛЮЧАТЕЛЬ 1А Понижающий стабилизатор напряжения 16-PDIP от -40 до 125 В
LM1575/LM2575/LM2575HV SIMPLE SWITCHER 1A Step-Down Voltage Regulator datasheet
PDF, 6.0 Мб, Версия: E, Файл опубликован: 3 апр 2013
Pin1616
Package TypeNBGNBG
Industry STD TermPDIPPDIP
JEDEC CodeR-PDIP-PR-PDIP-P
Package QTY2020
CarrierTUBETUBE
МаркировкаLM2575HVN-ADJ P+
Width (мм)6.356.35
Length (мм)21.75521.755
Thickness (мм)3.4293.429
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Control ModeVoltage Mode
Duty Cycle(Max)98 %
Iout(Max)1 A
Iq(Typ)10 мА
Package GroupPDIP
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)63 kHz
Switching Frequency(Min)42 kHz
ТипConverter
Vin(Max)60 В
Vin(Min)4 В
Vout(Max)57 В
Vout(Min)3.3 В
  • Cost-Effective Transformerless Offline Supply for Light Load Applications (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications. Thedesign uses a "capacitive-dropper" front-end combined with a LM46000 SIMPLE SWITCHERВ® buckregulator from Texas Instruments. The circuit provides 3.3 V at a minimum of 100 mA from a line supply of90 VAC to 265 VAC. Theory of operation as well as design equations and performance results are given.
  • Cap Drop Offline Supply for E-Meters
    PDF, 291 Кб, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications such assmart grid E-meter applications. The design uses a "capacitive-dropper" front-end combined with aLM46000 SIMPLE SWITCHERВ® buck regulator from Texas Instruments. The circuit provides 3.3 V at aminimum of 50 mA from a line supply of 90 VAC to 265 VAC. Theory of operation as well as designequa
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Switching Regulator Fundamentals (Rev. A)
    PDF, 324 Кб, Версия: A, Файл опубликован: 23 сен 2016
    Theswitchingregulatoris increasingin popularitybecauseit offersthe advantagesof higherpowerconversionefficiencyand increaseddesignflexibility(multipleoutputvoltagesof differentpolaritiescan begeneratedfroma singleinputvoltage).
LM2575HVNADJ/NOPB, LM2575HVN ADJ/NOPB
На английском языке: Datasheet Texas Instruments LM2575HVN-ADJ/NOPB
