Datasheet Texas Instruments SN65HVD12D — Даташит
СерияSN65HVD12
МодельSN65HVD12D
Дифференциальный трансивер 3,3 В 8-SOIC от -40 до 85
SNx5HVD1x 3.3-V RS-485 Transceivers datasheet
PDF, 1.2 Мб, Версия: O, Файл опубликован: 1 фев 2017
Package TypeD
Package QTY75
МаркировкаVP12
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Common Mode Range-7 to 12
DuplexHalf
Fail SafeIdle,Open,Short
Fault Protection-9 to 14 В
HBM ESD16 kV
ICC(Max)15.5 мА
IEC 61000-4-2 ContactN/A +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes256
Signaling Rate(Max)1 Mbps
Supply Voltage(s)(Nom)3.3 В
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • RS-485 failsafe biasing: Old versus new transceivers
    PDF, 131 Кб, Файл опубликован: 16 апр 2013
  • RS-485 for E-Meter Applications (Rev. A)
    PDF, 311 Кб, Версия: A, Файл опубликован: 6 авг 2004
    This application report discusses the best practices for designing energy meter communication circuits using the RS-485 standard. Component selection and performance tradeoffs are covered with reference to relevant standards such as IEC 61036 and DL/T 645. Reference design details are provided to help energy meter engineers successfully complete their own circuit designs.
  • 2Q 2013 Issue Analog Applications Journal
    PDF, 2.5 Мб, Файл опубликован: 16 апр 2013
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
На английском языке: Datasheet Texas Instruments SN65HVD12D
