Datasheet Texas Instruments CD74ACT158M96E4 — Даташит
Серия | CD74ACT158 |
Модель | CD74ACT158M96E4 |
Четырехинверторные мультиплексоры с 2 входами 16-SOIC от -55 до 125
![]() 8 предложений от 8 поставщиков Микросхема Логический контроллер, Multiplexer 1Element CMOS 8IN 16Pin SOIC T/R | |||
CD74ACT158M96E4 Texas Instruments | 24 ₽ | ||
CD74ACT158M96E4 Texas Instruments | 26 ₽ | ||
CD74ACT158M96E4 | по запросу | ||
Pin | 16 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | ACT158M |
Width (мм) | 3.91 |
Length (мм) | 9.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Полоса частот | 100 МГц |
Bits | 4 |
Количество каналов | 4 |
Configuration | 2:1 |
Digital input leakage(Max) | 5 uA |
ESD Charged Device Model | 0.75 kV |
ESD HBM | 2 kV |
F @ Nom Voltage(Max) | 90 Mhz |
Function | Encoder/Multiplexer |
ICC @ Nom Voltage(Max) | 0.08 мА |
Output Drive (IOL/IOH)(Max) | 24/-24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | ACT |
Тип | Standard |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 8.4 нс |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD74ACT158 (2)
- CD74ACT158M96 CD74ACT158M96E4
- Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
