Datasheet Texas Instruments ADS5411IPJY — Даташит
СерияADS5411
МодельADS5411IPJY
11 Bit 105 MSPS ADC datasheet
PDF, 897 Кб, Версия: A, Файл опубликован: 14 янв 2010
Pin52
Package TypePJY
Industry STD TermQFP
JEDEC CodeS-PQFP-G
МаркировкаADS5411I
Width (мм)10
Length (мм)10
Thickness (мм)1.4
Max Height (мм)1.6
Рекомендуемая замена
ReplacementADS5411IPGP
Replacement CodeQ
# Input Channels1
Analog Input BW(MHz)750
Approx. Price (US$)28.05 | 1ku
DNL(Max)(+/-LSB)0.25
ENOB(Bits)10.7
INL(Max)(+/-LSB)0.2
Input BufferYes
Input Range2.2V (p-p)
InterfaceParallel LVDS
Serial SPI Interface
Operating Temperature Range(C)-40 to 85
Package GroupHTQFP
Package Size: mm2:W x L (PKG)52HTQFP: 144 mm2: 12 x 12(HTQFP)
Power Consumption(Typ)(mW)1900
Reference ModeInt
Resolution(Bits)11
SFDR(dB)90
SINAD(dB)66.3
SNR(dB)66.4
Sample Rate(Max)(MSPS)105
RoHSНе совместим
  • Evaluation Modules & Boards: TSW1400EVM
    High Speed Data Capture and Pattern Generation Platform
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200EVM: Low Cost Portable Power Supply
  • High-Speed Analog-to-Digital Converter Basics
    PDF, 1.1 Мб, Файл опубликован: 11 янв 2012
    The goal of this document is to introduce a wide range of theories and topics that are relevant tohigh-speed analog-to-digital converters (ADC). This document provides details on sampling theorydata-sheet specifications ADC selection criteria and evaluation methods clock jitter and other commonsystem-level concerns. In addition some end-users will want to extend the performance capabil
  • Design Considerations for Avoiding Timing Errors during High-Speed ADC, LVDS Dat (Rev. A)
    PDF, 2.0 Мб, Версия: A, Файл опубликован: 22 май 2015
  • Why Use Oversampling when Undersampling Can Do the Job? (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 19 июл 2013
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Interleaving Analog-to-Digital Converters
    PDF, 64 Кб, Файл опубликован: 2 окт 2000
    It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • What Designers Should Know About Data Converter Drift
    PDF, 95 Кб, Файл опубликован: 2 окт 2000
    Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify.
  • Semiconductors > Data Converters > Analog to Digital Converter > High Speed ADC (>10MSPS)
На английском языке: Datasheet Texas Instruments ADS5411IPJY
