Datasheet Texas Instruments LM2842XQMKX/NOPB — Даташит
СерияLM2842-Q1
МодельLM2842XQMKX/NOPB
SIMPLE SWITCHER® Понижающий стабилизатор от 4,5 до 42 В, 0,6 А, тонкий SOT-23 6-SOT-23-THIN от -40 до 125
LM284x and LM284x-Q1 100, 300, or 600-mA 42-V Input Step-Down DC-DC Regulator in Thin SOT datasheet
PDF, 1.1 Мб, Версия: J, Файл опубликован: 21 фев 2017
Pin6
Package TypeDDC
Industry STD TermSOT-23-THIN
Package QTY3000
МаркировкаSB3B
Width (мм)1.6
Length (мм)2.9
Thickness (мм).87
Pitch (мм).95
Max Height (мм)1.1
Control ModeCurrent Mode
Duty Cycle(Max)94 %
Iout(Max)0.6 A
Iq(Typ)1.3 мА
Package GroupSOT-23-THIN
RatingAutomotive
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)1500 kHz
Switching Frequency(Min)950 kHz
ТипConverter
Vin(Max)42 В
Vin(Min)4.5 В
Vout(Max)34 В
Vout(Min)0.765 В
  • Evaluation Modules & Boards: LM2842XMK-ADJEV
    Evaluation Board for the LM2842
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
На английском языке: Datasheet Texas Instruments LM2842XQMKX/NOPB
Публикации по теме
