Datasheet Texas Instruments 5962-9223701MRA — Даташит
| Серия | CY54FCT541T |
| Модель | 5962-9223701MRA |
Восьмеричные буферы и линейные драйверы с выходами с 3 состояниями 20-CDIP от -55 до 125
8-Bit Buffers/Line Drivers With 3-State Outputs datasheet
PDF, 681 Кб, Файл опубликован: 11 окт 2001
Купить 5962-9223701MRA на РадиоЛоцман.Цены — от 2 891 до 4 873 ₽5 предложений от 5 поставщиков Микросхема Логический чип, Buffer/Line Driver 8CH Non-Inverting 3-ST CMOS 20Pin CDIP Tube | |||
| 5962-9223701MRA IDT | 2 891 ₽ | ||
| 5962-9223701MRA Texas Instruments | 4 873 ₽ | ||
| 5962-9223701MRA Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Width (мм) | 6.92 |
| Length (мм) | 24.2 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Bits | 8 |
| Тип входа | TTL |
| Рабочий диапазон температур | от -55 до 125 C |
| Тип выхода | CMOS |
| Package Group | CDIP |
| Package Size: mm2:W x L | See datasheet (CDIP) PKG |
| Rating | Military |
| Schmitt Trigger | No |
| Technology Family | FCT |
| VCC(Max) | 5.25 В |
| VCC(Min) | 4.75 В |
| Voltage(Nom) | 5 В |
| RoHS | See ti.com |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
Серия: CY54FCT541T (5)
- 5962-9223701M2A 5962-9223701MRA 5962-9223705MRA CY54FCT541TDMB CY54FCT541TLMB
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
59629223701MRA, 5962 9223701MRA
