Datasheet ТI SN74AVC16245DGVR — Даташит
| Серия | SN74AVC16245 |
| Модель | SN74AVC16245DGVR |
16-битный шинный трансивер с выходами с 3 состояниями 48-TVSOP от -40 до 85
16-Bit Bus Transceiver With 3-State Outputs datasheet
PDF, 364 Кб, Версия: L, Файл опубликован: 21 фев 2000
- Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i - AVC Logic Family Technology and Applications (Rev. A)PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control ( - Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
- 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74AVC16245 (3)
- 74AVC16245DGVRG4 SN74AVC16245DGGR SN74AVC16245DGVR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
