Datasheet Texas Instruments UC3526ADWTRG4 — Даташит
| Серия | UC3526A |
| Модель | UC3526ADWTRG4 |
Регулирующие широтно-импульсные модуляторы 18-SOIC от 0 до 70
Regulating Pulse Width Modulator datasheet
PDF, 597 Кб, Файл опубликован: 5 сен 1999
Купить UC3526ADWTRG4 на РадиоЛоцман.Цены — от 85 до 280 ₽13 предложений от 13 поставщиков IC REG CTRLR MULT TOP 18SOIC. Buck, Boost, Flyback, Forward Converter, Full-Bridge, Half-Bridge, Push-Pull Regulator Positive Output Step-Up, Step-Down, Step-Up/Step-Down DC-DC... | |||
| UC3526ADWTRG4 Texas Instruments | 104 ₽ | ||
| UC3526ADWTRG4 Texas Instruments | 141 ₽ | ||
| UC3526ADWTRG4 Texas Instruments | по запросу | ||
| Pin | 18 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | UC3526ADW |
| Width (мм) | 7.5 |
| Length (мм) | 11.5 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| Control Method | Voltage |
| Duty Cycle(Max) | 50 % |
| Frequency(Max) | 600 kHz |
| Frequency(Min) | 0.01 kHz |
| Gate Drive(Typ) | 0.2 A |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | SOIC |
| Rating | Catalog |
| Special Features | Error Amplifier,Multi-topology,Soft Start,Synchronization Pin |
| Topology | Boost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull |
| UVLO Thresholds On/Off | 7/6.8 В |
| Vin(Max) | 35 В |
| Vin(Min) | 8 В |
- DN-62 Switching Power Supply Topology Voltage Mode vs. Current ModePDF, 66 Кб, Файл опубликован: 5 сен 1999
This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UC3526A (6)
- UC3526ADW UC3526ADWG4 UC3526ADWTR UC3526ADWTRG4 UC3526AN UC3526ANG4
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
