Datasheet Texas Instruments LM5575MH/NOPB — Даташит
СерияLM5575
МодельLM5575MH/NOPB
Понижающий стабилизатор напряжения 6–75 В, 1,5 А, напряжение 1,5 А, 16-HTSSOP – от 40 до 125
LM5575/LM5575Q SIMPLE SWITCHER® 75V, 1.5A Step-Down Switching Regulator datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 4 апр 2013
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9292
CarrierTUBETUBE
МаркировкаLM5575MH
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCurrent Mode
Duty Cycle(Max)95 %
Iout(Max)1.5 A
Iq(Typ)1 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Tracking
Switching Frequency(Max)500 kHz
Switching Frequency(Min)50 kHz
ТипConverter
Vin(Max)75 В
Vin(Min)6 В
Vout(Max)70 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: LM5575EVAL
    75V, 1.5A Step-Down Switching Regulator Evaluation Module
  • Understanding and Applying Current-Mode Control Theory
    PDF, 409 Кб, Файл опубликован: 19 авг 2007
  • AN-1997 Error Amplifier Limitations in High-Performance Regulator Applications (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 6 май 2013
    The development of realistic predictions to assist the power supply engineer during the control loop design process is facilitated in this application report by appropriate small-signal and bode plot analysis, the validity of which is verified through simulation results.
  • Quick Start Guide for a 1.5 Amp Buck Regulator Using the LM5575 and LM25575 (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note provides an easy to use process to help users design a 1.5 Amp buck regular usingthe LM5575 and LM25575 switching regulators.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
Серия: LM5575 (4)
На английском языке: Datasheet Texas Instruments LM5575MH/NOPB
