Datasheet Texas Instruments LM5085MME/NOPB — Даташит
СерияLM5085
МодельLM5085MME/NOPB
Несинхронный понижающий контроллер на PFET-транзисторах с постоянным напряжением 4,5–75 В и постоянным временем включения, 8-VSSOP от -40 до 125
LM5085/-Q1 75-V Constant On-Time PFET Buck Switching Controller datasheet
PDF, 1.6 Мб, Версия: I, Файл опубликован: 12 авг 2015
Package TypeDGK
Industry STD TermVSSOP
Package QTY250
CarrierSMALL T&R
МаркировкаSSTB
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Control ModeConstant on-time (COT)
Duty Cycle(Max)100 %
Iout(Max)10 A
Iq(Typ)1.3 мА
Number of Phases1
Package GroupVSSOP
Regulated Outputs1
Special FeaturesAdjustable Current Limit,Enable,Frequency Synchronization
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)50 kHz
ТипController
Vin(Max)75 В
Vin(Min)4.5 В
Vout(Max)75 В
Vout(Min)1.25 В
  • Evaluation Modules & Boards: LM5085EVAL
    LM5085 - 75V Wide Vin Constant On-Time PFET Buck Switching Controller Evaluation Module
  • Constant Current Constant Voltage Buck Converter w/LM25085 (Rev. A)
    PDF, 377 Кб, Версия: A, Файл опубликован: 23 апр 2013
    In many applications, a constant-current constant-voltage (CC/CV) dc source is needed. The I-Vcharacteristic of a constant-current constant-voltage (CC/CV) source is shown in Figure 1. This applicationreport presents an external op-amp based accurate current limit circuit suitable for CC/CV operation whenthe required constant current range is very narrow.
  • Designing Non-Invert Buck-Boost (Zeta) Cnvrts w/a Buck P-FET Cntrl
    PDF, 299 Кб, Файл опубликован: 22 апр 2011
  • Transient Response versus Ripple – An Analysis of Ripple Injection Techniques
    PDF, 2.9 Мб, Файл опубликован: 28 апр 2014
    In this application note the implications of ripple injection techniques, aimed at minimizingoutput ripple voltage, on the transient response of a supply are highlighted. The results help choose a suitable ripple injection technique after striking a balance between the output ripple voltage and the transient response required by the load.
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM5085MME/NOPB
