Datasheet Texas Instruments LMK04805BISQX/NOPB — Даташит
СерияLMK04805
МодельLMK04805BISQX/NOPB
Малошумящий очиститель тактового джиттера с двойным каскадом ФАПЧ и встроенным ГУН 2,2 ГГц 64-WQFN от -40 до 85
LMK0480x Low-Noise Clock Jitter Cleaner with Dual Loop PLLs datasheet
PDF, 2.1 Мб, Версия: K, Файл опубликован: 24 дек 2014
Pin64
Package TypeNKD
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY2000
МаркировкаK04805BISQ
Width (мм)9
Length (мм)9
Pitch (мм).5
Max Height (мм).8
Количество входов2
Количество выходов14
Output Frequency(Max)2370 МГц
Output Frequency(Min)0.22 МГц
Output LevelLVCMOS,LVDS,LVPECL
Package GroupWQFN
Package Size: mm2:W x L64WQFN: 81 mm2: 9 x 9(WQFN) PKG
RMS Jitter0.111
Special FeaturesHoldover mode,Int. xtal oscillator,Manual/auto switch,SPI,uWire
Supply Voltage(Max)3.45 В
Supply Voltage(Min)3.15 В
VCO Frequency(Max)2370 МГц
VCO Frequency(Min)2148 МГц
  • Evaluation Modules & Boards: TSW3084EVM
    Wideband Transmit Signal Chain Evaluation Board and Reference Design
  • Evaluation Modules & Boards: DAC34SH84EVM
    DAC34SH84 Quad-Channel, 16-Bit, 1.5-GSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TSW30SH84EVM
  • Evaluation Modules & Boards: TSW30H84EVM
  • Evaluation Modules & Boards: LMK04805BEVAL
    Clock Jitter Cleaner With Dual Cascaded PLLs and Integrated 2.2 GHz VCO
  • Evaluation Modules & Boards: TSW1265EVM
    Wideband Dual Receiver Reference Design and Evaluation Platform
  • Evaluation Modules & Boards: TSW4806EVM
    TSW4806EVM: Low Cost Programmable Clock Source
  • Evaluation Modules & Boards: TSW1266EVM
    Wideband RF-to-Digital Complex Feedback Receiver: Dual 12-Bit 800MSPS ADC, DVGA and Clock Solution
  • Using the LMK0480x/LMK04906 for Hitless Switching and Holdover
    PDF, 3.8 Мб, Файл опубликован: 12 июл 2013
    This application report discusses some of the key performance results when using LMK0480x/LMK04906to implement hitless switching between reference clocks. Hitless Switching is required in certainapplications such as SONET/SDH/line port cards and routers/switchers in order to minimize thepropagation of phase transients to the clock outputs during reference clock switching. On loss of all vali
Серия: LMK04805 (3)
  • Semiconductors > Clock and Timing > Clock Jitter Cleaners > Dual / Cascaded PLL
На английском языке: Datasheet Texas Instruments LMK04805BISQX/NOPB
