Datasheet Texas Instruments LM2587SX-12/NOPB — Даташит
СерияLM2587
МодельLM2587SX-12/NOPB
SIMPLE SWITCHER® 4–40 В, 5 А, повышающий обратный стабилизатор с широким напряжением питания 5-DDPAK/TO-263 от -40 до 125
LM2587 SIMPLE SWITCHER 5A Flyback Regulator datasheet
PDF, 4.2 Мб, Версия: D, Файл опубликован: 3 апр 2013
Pin55
Package TypeKTTKTT
Industry STD TermTO-263TO-263
JEDEC CodeR-PSFM-GR-PSFM-G
Package QTY500500
CarrierLARGE T&RLARGE T&R
Маркировка-12 P+LM2587S
Width (мм)8.428.42
Length (мм)10.1610.16
Thickness (мм)4.584.58
Pitch (мм)1.71.7
Max Height (мм)4.834.83
Duty Cycle(Max)98 %
Iq(Typ)11 мА
Package GroupDDPAK/TO-263
Regulated Outputs1
Special FeaturesN/A
Switch Current Limit(Min)5 A
Switch Current Limit(Typ)6.5 A
Switching Frequency(Max)115 kHz
Switching Frequency(Min)85 kHz
ТипConverter
Vin(Max)40 В
Vin(Min)4 В
Vout(Max)60 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: LM2587EVAL
    SIMPLE SWITCHERВ® 5A Flyback Regulator Eval Board
  • Softstart Using Constant Current Constant Voltage Approach
    PDF, 337 Кб, Файл опубликован: 24 июл 2015
    In many systems backup power is provided either by batteries or simply by a large value capacitor. Inthese applications the capacitor would only provide the current when the primary power source fails.Further, these applications are usually for light load currents. During normal operation the backupcapacitors are kept charged up by a DC/DC converter. The challenge involved in an application
  • Working With Boost Converters
    PDF, 159 Кб, Файл опубликован: 15 июн 2015
    This brief note highlights some of the more common pitfalls when using boost regulators. These includemaximum achievable output current and voltage, short circuit behavior and basic layout issues. It isassumed that the reader is familiar with the basic operation of a boost regulator.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Dual LM2587 Boost Converter, -5V input to +5V, 2A Output
    PDF, 48 Кб, Файл опубликован: 21 мар 2007
  • Negative Input to Positive Output made SIMPLE
    PDF, 645 Кб, Файл опубликован: 9 июл 2015
    There can be quite a few applications that require a conversion from a negative input voltage to a positive output voltage. This design space along with being limited is not well explored. There are a few ways to go about doing it. In this application note we will go over the use of an integrated boost regulator to convert a negative input voltage to a positive output voltage.
  • Inverted SEPIC Made SIMPLE
    PDF, 408 Кб, Файл опубликован: 31 июл 2015
    There can be quite a few applications that require a conversion from a negative input voltage to a negativeoutput voltage and there are a few ways to go about doing it. The telecom industry is one such examplewhere the rails are usually negative. This design space along with being limited is not well explored. In thisapplication note we will go over the use of an integrated boost regulator i
  • AN-1095 Design of Isolated Converters Using Simple Switchers (Rev. B)
    PDF, 631 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note discusses the design of isolated converters using simple switchers.
  • AN-1082 Adjust or Synchronize LM2586/88 Switching Frequency (Rev. B)
    PDF, 69 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Switching frequency is a very important parameter in switching power converters. As the switchingfrequency increases, the physical size of magnetic elements and other components in the circuit reducesignificantly. Switching frequency also plays a great role in control loop gain and compensation design.Switching frequency determines the maximum allowable bandwidth of the control loop. Switchi
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Increasing Available Load Power in an LM2587 Boost Regulator (by Paralleling)
    PDF, 66 Кб, Файл опубликован: 21 мар 2007
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
LM2587SX12/NOPB, LM2587SX 12/NOPB
На английском языке: Datasheet Texas Instruments LM2587SX-12/NOPB
