Datasheet ТI ADS1286UBG4 — Даташит
| Серия | ADS1286 |
| Модель | ADS1286UBG4 |
12-битный аналого-цифровой преобразователь с микровыборкой мощности 8-SOIC от -40 до 85
12-Bit Micro Power Sampling Analog-To-Digital Converter datasheet
PDF, 473 Кб, Файл опубликован: 27 сен 2000
- Voltage Reference Scaling Techniques Increase Converter and Resolution Accuracy (Rev. A)PDF, 67 Кб, Версия: A, Файл опубликован: 8 май 2015
- Interfacing the ADS7822 to synchronous serial port of the 80x51 MicrocontrollerPDF, 69 Кб, Файл опубликован: 27 сен 2000
Analog-to-digital converters can be controlled by a normal I/O port or with the synchronous serial port of the 80x51 microcontrollers. The synchronous serial port is more efficient, however, there are some pitfalls to be aware of when configuring the 8-pin A/D converters (ADS1286, ADS7816, ADS7817 and ADS7822) from Burr-Brown. This application bulletin describes how to get around these pitfalls an - Coding Schemes Used with Data Converters (Rev. A)PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
- Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
The input structure circuit of a successive-approximation register analog-to-digital converter (SAR ADC) incombination with the driving circuit forms a transfer function that can be used to determine minimum acquisition times for different types of applied input signals. This application report, which builds on Determining Minimum Acquisition Times for SAR ADCs When a Step Function is Applied to - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1286 (21)
