Datasheet Texas Instruments SN74AHCT245PWE4 — Даташит
СерияSN74AHCT245
МодельSN74AHCT245PWE4
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-TSSOP от -40 до 125
SNx4AHCT245 Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 1.6 Мб, Версия: P, Файл опубликован: 27 июн 2014
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY70
МаркировкаHB245
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Bits8
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-8/8 мА
Package GroupTSSOP
Schmitt TriggerNo
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)9.5 нс
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74AHCT245PWE4
