Datasheet Texas Instruments MSP430FR69891IPZR — Даташит
СерияMSP430FR69891
МодельMSP430FR69891IPZR
MSP430FR69891 Микроконтроллер ULP, 16 МГц, 128 КБ FRAM, 2 КБ SRAM, 83 ввода-вывода, ADC12, ЖК-дисплей, AES 100-LQFP от -40 до 85
MSP430FR698x(1), MSP430FR598x(1) Mixed-Signal Microcontrollers datasheet
PDF, 2.7 Мб, Версия: C, Файл опубликован: 9 мар 2017
IC MCU 16BIT 128KB FRAM 100LQFP. CPUXV2 MSP430TM FRAM Microcontroller IC 16-Bit 16MHz 128KB (128K x 8) FRAM 100-LQFP (14x14)....
MSP430FR69891IPZR
185 ₽
MSP430FR69891IPZR
329 ₽
MSP430FR69891IPZR
471 ₽
Hi-Tech Circuit Group
MSP430FR69891IPZR
Pin100
Package TypePZ
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаFR69891
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADCADC12 - 16ch
AESAES256
Active Power101.25 uA/MHz
Additional FeaturesLCD,Real-Time Clock,Watchdog,Scan Interface,Temp Sensor,Brown Out Reset,IrDA,IP Protection
BSLI2C
CPUMSP430
Comparators16
DMA3
Featuredfr6
Тактовая частота16 МГц
GPIO Pins83
I2C2
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory128 KB
Package GroupLQFP
Package Size: mm2:W x L80LQFP: 196 mm2: 14 x 14(LQFP) PKG
RAM2 KB
SPI4
Security EnablerCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection
Special I/ON/A
Standby Power0.9 LPM3-uA
Timers - 16-bit5
UART2
Wakeup Time7 us
  • Evaluation Modules & Boards: MSP-FET430U100D
    100-pin Target Development Board and MSP-FET Programmer Bundle for MSP430FRxx FRAM MCUs
  • Evaluation Modules & Boards: MSP-TS430PZ100D
    MSP-TS430PZ100D- 100-pin Target Development Board for MSP430FRxx FRAM MCUs
  • Development Kits: MSP-FET430U48C
    48-pin Target Development Board and MSP-FET Programmer Bundle for MSP430FRxx FRAM MCUs
  • Evaluation Modules & Boards: MSP-TS430RGZ48C
    MSP-TS430RGZ48C - 48-pin Target Development Board for MSP430FRxx FRAM MCUs
  • Evaluation Modules & Boards: MSP-EXP430FR6989
    MSP430FR6989 LaunchPad Development Kit
    MSP EnergyTrace Technology
  • Method to Select the Value of LC Sensor for MSP430 Extended Scan Interface (ESI)
    PDF, 374 Кб, Файл опубликован: 28 авг 2014
    This document describes a method that can be used to select an LC sensor for use with the MSP430в„ў Extended Scan Interface (ESI).
  • LC Sensor Rotation Detection With MSP430 Extended Scan Interface (ESI)
    PDF, 2.2 Мб, Файл опубликован: 28 авг 2014
    This application report describes the implementation of a flow meter using the Texas Instruments MSP430FR6989 microcontroller with the Extended Scan Interface (ESI) module. This module can provide a contactless sensing approach to detecting a rotating disc. The number of rotations of the disc indicates the volume flow of gas or water and can be used to calculate the fee for the user. This applicat
  • Adjustment of ESIOSC Oscillator Frequency (Rev. A)
    PDF, 192 Кб, Версия: A, Файл опубликован: 30 янв 2015
    The MSP430FR698x Extended Scan Interface (ESI) uses two clock sources. These clocks are ACLK and a high-frequency clock generated by the ESI oscillator, ESIOSC. ESIOSC is realized as an RC-oscillator and shows a temperature and voltage dependency. However, a hardware-supported measurement of ESIOSC frequency and adjustment by software allows compensating for the frequency drift. This application r
  • Migrating From MSP430FW42x Scan Interface to MSP430FR6x8x/FR5x8x ESI (Rev. A)
    PDF, 95 Кб, Версия: A, Файл опубликован: 6 фев 2015
    The purpose of this application report is to facilitate the migration of designs based on the MSP430FW42x Scan Interface (SIF) to the MSP430FR5xx/FR6xx Extended Scan Interface (ESI). This document describes the main differences between the two peripheral modules and provides migration solutions covering both software and hardware aspects.
  • Secure In-Field Firmware Updates for MSP MCUs
    PDF, 223 Кб, Файл опубликован: 17 ноя 2015
    In-field firmware update is a feature that is increasingly used in microcontroller-based applications today and important benefits include service and support to products that are already deployed in the field (for example, being able to correct bugs or add new functionalities). As common as in-field firmware updates are in embedded systems, this feature is also commonly exploited by attackers; if
  • Random Number Generation Using MSP430FR59xx and MSP430FR69xx Microcontrollers
    PDF, 113 Кб, Файл опубликован: 18 янв 2017
    Random number generation has a role in a variety of applications, such as cryptography and tamper detection.In digital systems, it becomes difficult to introduce the concept of true randomness as a machine executes code in the sequence it is programed. This introduces the notion of true random number generators (TRNGs) and pseudorandom number generators (PRNGs), also known as deterministic rando
  • Getting Started With EEMBC ULPBench on MSP-EXP430FR5969 (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 29 янв 2015
    This is a getting started guide for obtaining the ULPMarkв„ў-CP score using the Embedded Microprocessor Benchmark Consortium (EEMBC) ULPBench and EnergyMonitor with the MSP430FR5969 microcontroller (MCU). This document uses the MSP-EXP430FR5969 LaunchPad development kit as the target evaluation module (EVM) for performing the benchmark.
  • Migrating From MSP430F4xx Family to MSP430FR58xx/FR59xx/FR68xx/FR69xx Family (Rev. B)
    PDF, 183 Кб, Версия: B, Файл опубликован: 3 ноя 2016
    This application report enables easy migration from MSP430F4xx flash-based MCUs to the MSP430FR58xx/59xx/68xx/69xx family of FRAM-based MCUs. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR58xx/FR59xx/68xx/69xx devices, see the MSP430FR58xx, MSP430FR59xx, MSP430FR68xx, and MSP430FR69xx Family User's Guide.
  • MSP430 Advanced Power Optimizations: ULP Advisor SW and EnergyTrace Technology
    PDF, 4.0 Мб, Файл опубликован: 9 июн 2014
    MSP430 microcontrollers are designed specifically for ultra-low-power applications. Features such as multiple low-power modes, instant wakeup, intelligent autonomous peripherals, and much more to enable such ultra-low-power capabilities. Texas Instruments provides valuable tools to help the programmer fully use these benefits and optimize power consumption of the target application. This app
  • Designing With the MSP430FR58xx, FR59xx, FR68xx, and FR69xx ADC (Rev. A)
    PDF, 137 Кб, Версия: A, Файл опубликован: 30 мар 2016
    Designing an application with the analog-to-digital converter (ADC) requires several considerations to optimize for power and performance. This application report discusses the basics of how you would analyze a data sheet and user's guide to design your application. It goes into the fundamentals of how to optimize your design based on the external requirements and available ADC configurations. The
  • MSP430 FRAM Technology – How To and Best Practices
    PDF, 326 Кб, Файл опубликован: 23 июн 2014
    FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specif
  • MSP430 FRAM Quality and Reliability (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
    FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and endura
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • Migrating from the MSP430F5xx,F6xx Family to the MSP430FR58xx/FR59xx/68xx Family (Rev. D)
    PDF, 151 Кб, Версия: D, Файл опубликован: 3 ноя 2016
    This application report helps enable easy migration from MSP430F5xx and MSP430F6xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight differences between the
  • Migrating from the MSP430F2xx,G2xx Family to the MSP430FR58xx/FR59xx/68xx/69xx (Rev. E)
    PDF, 179 Кб, Версия: E, Файл опубликован: 3 ноя 2016
    This application report enables easy migration from MSP430F2xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx family of FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two f
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR69891IPZR
