Datasheet Texas Instruments OPA2658UB — Даташит
Серия | OPA2658 |
Модель | OPA2658UB |
Двойной широкополосный маломощный операционный усилитель с токовой обратной связью 8-SOIC
![]() 10 предложений от 10 поставщиков Микросхема Операционный усилитель, Dual Wideband, Low Power, Current Feedback Operational Amplifier 8-SOIC | |||
OPA2658UB Texas Instruments | 91 ₽ | ||
OPA2658UB Texas Instruments | 215 ₽ | ||
OPA2658UB/2K5 Texas Instruments | по запросу | ||
OPA2658UB | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | OPA2658U |
Replacement Code | Q |
RoHS | Не совместим |
- Evaluation Modules & Boards: DEM-OPA26XXE
DEM-OPA26xxE: Demonstration Fixture
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: DEM-OPA268XU
DEM-OPA268xU: Demonstration Fixture
- The Current-Feedback Op Amp: A High-Speed Building BlockPDF, 117 Кб, Файл опубликован: 2 окт 2000
Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2658 (7)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
