Datasheet Texas Instruments CD54HC4040F3A — Даташит
СерияCD54HC4040
МодельCD54HC4040F3A
Высокоскоростная логика КМОП, 12-ступенчатый двоичный счетчик, 16-CDIP, от -55 до 125
CD54HC4040, CD74HC4040, CD54HCT4040, CD74HCT4040 datasheet
PDF, 462 Кб, Версия: D, Файл опубликован: 16 окт 2003
Микросхема Счётчик, Counter Single 12Bit Binary UP 16Pin CDIP Tube
Элитан
CD54HC4040F3A
Renesas
3 623 ₽
ТаймЧипс
CD54HC4040F/3A
CD54HC4040F3A8500401EA
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаCD54HC4040F3A8500401EA
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Bits12
F @ Nom Voltage(Max)28 Mhz
FunctionCounter
ICC @ Nom Voltage(Max)0.08 мА
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
ТипBinary
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)30 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC4040 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC4040F3A
