Datasheet Texas Instruments SN74ALVC08RGYRG4 — Даташит
СерияSN74ALVC08
МодельSN74ALVC08RGYRG4
Четырехканальный логический элемент «И» с 2 входами 14-VQFN от -40 до 85
SN74ALVC08 datasheet
PDF, 778 Кб, Версия: I, Файл опубликован: 31 авг 2004
IC GATE AND 4CH 2-INP 14VQFN. AND Gate IC 4 Channel 14-VQFN (3.5x3.5). Logic - Gates and Inverters
Рутоника
SN74ALVC08RGYRG4
12 ₽
SN74ALVC08RGYRG4
13 ₽
TradeElectronics
SN74ALVC08RGYRG4
SN74ALVC08RGYRG4
Pin14
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаVA08
Width (мм)3.5
Length (мм)3.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Bits4
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupVQFN
Package Size: mm2:W x L14VQFN: 12 mm2: 3.5 x 3.5(VQFN) PKG
Schmitt TriggerNo
Technology FamilyALVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)5.3,3.3,3,2.9 нс
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • Semiconductors > Logic > Gate > AND Gate
На английском языке: Datasheet Texas Instruments SN74ALVC08RGYRG4
