Datasheet Texas Instruments LMV712MMX — Даташит
СерияLMV712-N
МодельLMV712MMX
Низкая мощность, низкий уровень шума, высокая выходная мощность, двойной операционный усилитель RRIO с независимым отключением, 10-VSSOP от -40 до 85
LMV712-N, LMV712-N-Q1 Low Power, Low Noise, High Output, RRIO Dual Operational Amplifier With Independent Shutdown datasheet
PDF, 1.2 Мб, Версия: J, Файл опубликован: 18 ноя 2016
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
МаркировкаA61
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Рекомендуемая замена
ReplacementLMV712MMX/NOPB
Replacement CodeS
Additional FeaturesShutdown
Approx. Price (US$)0.49 | 1ku
АрхитектураCMOS
CMRR(Min)(dB)50
CMRR(Typ)(dB)80
GBW(Typ)(MHz)5
Input Bias Current(Max)(pA)115
Iq per channel(Max)(mA)1.7
Iq per channel(Typ)(mA)1.17
Number of Channels(#)2
Offset Drift(Typ)(uV/C)5
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)35
Package GroupVSSOP
Package Size: mm2:W x L (PKG)See datasheet (DSBGA)
See datasheet (WSON)
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)5
Total Supply Voltage(Max)(+5V=5, +/-5V=10)5.5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.7
Vn at 1kHz(Typ)(nV/rtHz)20
Vos (Offset Voltage @ 25C)(Max)(mV)3
RoHSНе совместим
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LMV712MMX
