Datasheet Texas Instruments SN74CBTD3384CDBQR — Даташит
Серия | SN74CBTD3384C |
Модель | SN74CBTD3384CDBQR |
10-битные переключатели шины на полевых транзисторах со сдвигом уровня и понижением напряжения -2 В 24-SSOP от -40 до 85
SN74CBTD3384C datasheet
PDF, 993 Кб, Версия: A, Файл опубликован: 15 окт 2003
Pin | 24 |
Package Type | DBQ |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | CBTD3384C |
Width (мм) | 3.9 |
Length (мм) | 8.65 |
Thickness (мм) | 1.5 |
Pitch (мм) | .64 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Powered off protection,-2V undershoot protection,Voltage Level Shifting |
Полоса частот | 20 МГц |
Configuration | 1:1 SPST |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 5 пФ |
Input/Output ON-state Capacitance(Typ) | 12.5 пФ |
Количество каналов | 10 |
OFF-state leakage current(Max) | 10 мкА |
Package Group | SSOP |
Package Size: mm2:W x L | 24SSOP: 52 mm2: 6 x 8.65(SSOP) PKG |
Rating | Catalog |
Ron(Max) | 20 Ohms |
Ron(Typ) | 3 Ohms |
Supply Current(Max) | 1500 uA |
Supply Range | 5.5 Max |
VIH(Min) | 2 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 4.5 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- CBT-C, CB3T, and CB3Q Signal-Switch FamiliesPDF, 584 Кб, Файл опубликован: 4 фев 2003
Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot - VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CBTD3384C (15)
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
